Music Sugar Bytes Effectrix 1.4.2
OS version: OS X 10.6 or later
    Version: 1.4.2
    Processor type(s) & speed: 1 GHz or faster
    Serial provided in text file along with Windows keygen if desired
    Includes: VST / AU / RTAS / AAX
    v1.4.2 release notes unavailable
    1.4 Update now online!
    Effectrix is now available as 64bit version, so it can now be used in all super modern production environments without problems. Additionally there are new improvements like MidiLearn for Bypass, Chaos and Random.
    Effectrix is the perfect tool for sequenced sound manipulations. Tweak your beats, create new rhythms, reverse parts, stretch others, apply delaylines; even create melodies with atonal material. If you like, do it all at once! Have it your way with 14 Candy Effects of Sugar Bytes latest Bang Effectrix, each one providing its own stepsequencer and two modulation-sequencers.
    32 step sequencer for activating the effects
    2 modulation-sequencer for parameter remote for each effect
    12 subpatterns, triggered via MIDI notes and host automation
    14 innovative effects
    Effectrix as a musical instrument.
    See Effectrix as a musical instrument with lots of possibilities for different expressions of existing material. Sounds of any kind can be transformed to exciting beat structures and soundscapes.
    Looper´s Heaven
    Effectrix contains the most innovative loopers so far.
    Besides classical looping of passages in realtime, loops can also be scratched, stretched, reversed or modulated in loopsize and pitch. All that very convenient in realtime, without latency, time consuming editing or complex wirings.
    Scratcher´s Heaven
    Until now not available, now you have it twice: Scratching in realtime. Effectrix gives you two advanced scratching Effects for placing scratches exactly where they belong in your arrangement. In relatime.
    You dont have to make samples anymore, to scratch them using low-quality freeware or too expensive DJ Software, bounce them, cut them, place them in your song...
    Use the Scratch Looper / the Vinyl Effect to scratch your tracks at any time, using different methods and the advanced possibilities that open up using the modulation tracks. The Scratch Looper gives you advanced in-depth controls to create stunning scratches. The Vinyl effect scratches the signal without looping it and serves with the Stop Mode which gives you the classical sound of a vinyl record stopped with your hand. Little hint: use several stops after each other to create the coolest beats.
    Effectrix as a groovebox
    Use Effectrix to refine your beats, enrich them with scratches or give them further complexity by looping, delaying, or reverberating phrases.
    Using the Tonal Delay you can create melodies out of any material. The Stutter effect provides classical gating as well as sequenced panning and enveloping (working out transients).
    Effectrix as a livetool
    Stun you audience with grooving sounds and breaks which needed hours of editing in the past. If you use Effectrix in "Run on MIDI note" mode, the effect sequences will only be played when you hit a MIDI note. That way you can modify your live audio and introduce exciting breaks at any time, either being a DJ, Bandmember or Laptop artist.
    Effectrix as a source of inspiration
    Dive into the world of endless possibilities opening up with Effectrix. Use Effectrix on the master bus or on single tracks, experiment with several Effectrix instances in chain, trigger effect sequences with midi notes or let Effectrix run permanently. Play with grooves like never before. Put a reverb exactly onto the snare, introduce delay lines on certain places in your groove, create new kinds of sounds by relooping looped or scratched stuff. Effectrix is an instrument with an endeless depth of possibilities.
    Version: 1.4.2
