Sublime Text 3 (Beta) 3083 2015-05-16
    Sublime Text
    11.95 MB
    Version: 3 (Beta) - Build 3083
    Block connections to: sublimetext.com
    Yosemite Compatible Patcher
    Courtesy of Special [K]
    Instructions:
    1. Patch and register with any serial.
    Release Date: March 26, 2015
    Build 3083
    Fixed high CPU usage caused by a corrupt index. This was occuring for some users upgrading from 3065
    Added setting index_workers to control the number of threads used for file indexing. By default the number of threads is based on the number of CPU cores. By setting index_workers to 1 or 2, indexing will be slower, but less intrusive
    Fixed a crash when showing the Command Palette with an empty .sublime-build file
    Tab completion no longer completes numbers. Edit/Show Completions can still be used for this
    Sublime Text is a sophisticated text editor for code, markup and prose.
    You'll love the slick user interface, extraordinary features and amazing performance.
    Some things users love about Sublime Text:
    Goto Anything
    Use Goto Anything to open files with only a few keystrokes, and instantly jump to symbols, lines or words.
    Triggered with ⌘P, it is possible to:
    Type part of a file name to open it.
    Type @ to jump to symbols, # to search within the file, and : to go to a line number.
    These shortcuts can be combined, so [email protected] may take you to a function read_file within a file text_parser.py. Similarly, tp:100 would take you to line 100 of the same file.
    Multiple Selections
    Make ten changes at the same time, not one change ten times. Multiple selections allow you to interactively change many lines at once, rename variables with ease, and manipulate files faster than ever.
    Try pressing ⇧⌘L to split the selection into lines and ⌘D to select the next occurrence of the selected word. To make multiple selections with the mouse, take a look at the Column Selection documentation.
    Command Palette
    The Command Palette holds infrequently used functionality, like sorting, changing the syntax and changing the indentation settings. With just a few keystrokes, you can search for what you want, without ever having to navigate through the menus or remember obscure key bindings.
    Show the Command Palette with ⌘⇧P.
    Distraction Free Mode
    When you need to focus, Distraction Free Mode is there to help you out. Distraction Free Mode is full screen, chrome free editing, with nothing but your text in the center of the screen. You can incrementally show elements of the UI, such as tabs and the find panel, as you need them.
    You can enter Distraction Free Mode using the View/Enter Distraction Free Mode menu.
    Split Editing
    Get the most out of your wide screen monitor with split editing support. Edit files side by side, or edit two locations in the one file. You can edit with as many rows and columns as you wish.
    Take advantage of multiple monitors by editing with multiple windows, and using multiple splits in each window.
    Take a look at the View/Layout menu for split editing options. To open multiple views into the one file, use the File/New View into File menu item.
    Instant Project Switch
    Projects in Sublime Text capture the full contents of the workspace, including modified and unsaved files. You can switch between projects in a manner similar to Goto Anything, and the switch is instant, with no save prompts - all your modifications will be restored next time the project is opened.
    Plugin API
    Sublime Text has a powerful, Python based plugin API. Along with the API, it comes with a built in Python console to interactively experiment in real time.
    Customize Anything
    Key Bindings, Menus, Snippets, Macros, Completions and more - just about everything in Sublime Text is customizable with simple JSON files. This system gives you flexibility as settings can be specified on a per-file type and per-project basis.
    Cross Platform
    Sublime Text is available for OS X, Windows and Linux. One license is all you need to use Sublime Text on every computer you own, no matter what operating system it uses.
    Sublime Text uses a custom UI toolkit, optimized for speed and beauty, while taking advantage of native functionality on each platform.
    Version: 2015-05-16
