Video Sorenson Squeeze Desktop Pro v10.0.0
Video
    146.22 MB
    Sorenson Squeeze Desktop Pro v10.0.0 *INCL.KEYMAKER*
    Cracked by: symmetry Release-Name: CR-3DS6_.ZIP
    Supplied: CORE Release-Date: 2014/10/16
    Packaged: Bergelmir Release-Type: Util
    Protection: Serial OS: MacOSX
    Crack/SN: Serial Language: English
    Rating: [You decide!] Disks: 31
    DESCRiPTiON: Sorenson Squeeze is a video encoding tool, enabling users to
    efficiently re-purpose video content for web, CD or DVD
    applications
    Sorenson Squeeze Compression Suite includes Sorenson Video Pro
    Sorenson Spark Pro, Sorenson MPEG-4 Pro and Sorenson AVC Pro video
    codecs
    It encodes to multiple formats including QuickTime, Windows Media
    Flash Video, Silverlight, WebM & WMV
    It uses multiple codecs, including the Sorenson codecs SV3 Pro and
    Spark, H.264, H.263, VP6, VC1, and MPEG2
    Squeeze offers native plugins to Avid, Apple Final Cut Pro and
    Adobe Premiere (CS4, CS5) NLEs
    iNSTALL/REGiSTER NOTES: 1. Install
    2. Use our keymaker to generate a serial for a company to use
    inside the installer. All the other fields besides company and
    serial do not matter. You will need to be offline or have a
    firewall to block the installer from attempting to check the
    details remotely
    3. After the installation is complete, you have a few different
    options to block the forced online check of the serial. See
    below for more information
    4. Done
    Notes: The best method is to use the patch button inside our
    keymaker and direct it to Squeeze.app found inside Applications
    directory. This will make Squeeze think it has been successfully
    authorized and disable the online check. You will need to enter
    admin details for the patch to work. The other method is to block
    the phone home with some firewall like Little Snitch or in the
    hosts file. The reason why both of these methods aren't
    recommended is because Squeeze will continually try to send your
    details causing a pointless drain on system resources. For the
    hosts file, add following:
    # Block Sorenson Squeeze Activation
    127.0.0.1 reg.sorensonmedia.com
    One final note: Unicode or extended ASCII names are broken for
    OSX. Fail coding on Sorenson's part
    Version: v10.0.0
