PhotoLine v 19.01
Serial OS: MacOSX
    Computerinsel PhotoLine v18.53 *INCL.KEYMAKER*
    Cracked by: symmetry Release-Name: CR-P567_.ZIP
    Supplied: CORE Release-Date: 2014/12/17
    Packaged: Neurotika Release-Type: Util
    Protection: Serial OS: MacOSX
    Crack/SN: Serial Language: Multilingual
    Rating: [You decide!] Disks: 6
    DESCRiPTiON: PhotoLine is an image processing utility, image browser, layout
    program, vector editor, batchconverter and Web editor with a
    multitude of powerful functions
    PhotoLine is available as 32 or 64 bit application. Imaging
    functions supported are Lab, CMYK, 16 bit channels, ICC profiles
    and raw data profiles for digital cameras. PhotoLine offers all
    the tools you need: Painting, cloning, filtering, blending and
    flood fill, special effects like squirl, shadow, glowing, distorb
    morphing, 3d projection. Also supports, working layers, clipping
    layers, dynamic layer effects. EXIF digital camera data and IPTC
    data are also supported. Multiple undo/redo levels, plugin filters
    and much more
    Save and read your PDF-files with PhotoLine. Create vector
    graphics, add, remove, move vector points. Convert lines to
    beziers, fill with pattern, etc
    PhotoLine also has an action recorder. You can record your jobs
    and use the batch converter to convert them into an animated gif
    Do all your work for the Web with PhotoLine. Transparent and
    animated GIFs, animations, JPEG2000, HD-Photo, Flash format (swf)
    Create animated buttons, image maps, and more with PhotoLine!
    Languages: DE, EN, FR, IT, ZH
    iNSTALL/REGiSTER NOTES: Use our keymaker to register the application
  1. PhotoLine
    Version: 18.53
