Video mocha Pro 4.1.2
    mocha Pro
    159.0 MB
    Version: 4.1.2
    Processor type(s) & speed: 64 bit
    RAM minimum: 1 GB
    New: mocha Pro 4.1 with advanced tools for stereoscopic 3D, customizable keyboard shortcuts, Adobe Premiere support, open splines, python scripting, improved format support and more.
    mocha Pro is a stand alone software utility optimized for visual effects and post-production challenges.
    Planar Tracking
    When other trackers fail, users turn to mocha's rock solid tracking.
    mocha’s 2.5D planar motion tracking engine accurately follows translation, scale, rotation, skew and perspective. Unlimited tracking layers handle reflections, obstructed and blurred objects, even areas with low detail. The AdjustTrack module and overlay tools help solve tracking challenges with pixel-perfect accuracy.
    Advanced Roto Tools
    Create animated roto masks with less keyframes.
    X-spline and Bezier creation tools are purposely designed for artists to easily create detailed roto shapes. When linked to mocha’s planar tracking, roto shapes inherit motion and perspective, dramatically reducing manual keyframe work. Advanced tools for shape editing include per-point edge feathering, join layers tool, transform tool, group layers and more making mocha the ideal system for rotoscoping.
    Object Removal & Clean Plating
    Automatically remove unwanted elements, wires, rigs and tracking marks with ease.
    mocha Pro’s Remove Module is an amazing alternative to traditional clone and paint techniques for getting rid of unwanted pixels and removing objects. It automatically detects and blends pixels from other frames with little user input, offering massive time savings. mocha Pro’s clean plate functionality imports and corrects fixed frames for digital beauty work and matte painting.
    3D Camera Solver
    Camera tracking for 3D visual effects.
    Solve 3D match moving capabilities with planar ease. Unlike feature based tracking, mocha solves the 3D camera based on user-selected planes. This fast and easy-to-use solution is ideal for set extensions, 3D text and particle tracking. Additionally the 3D solver can be used to assist other 3D tracking applications on difficult shots with low detail or significant foreground occlusions.
    Stereoscopic 3D
    New tools optimized for stereo 3D projects.
    mocha Pro 4 has been updated to support native stereo 3D. This new workflow uses planar tracking analysis on “both eye views” to reduce manual offsets and tedious keyframe work on stereo 3D rotoscoping, tracking, 3D camera solve and object removal.
    Lens Module
    Calibrate, correct and remove lens distortion.
    This simple and easy-to-use interface allows users to calibrate the distortion introduced by camera lenses. Unwanted lens distortion can be removed or matched for realistic compositing. Export to the free mocha Lens plug-in for After Effects or export distortion map data for Nuke, Flame, Fusion and more*.
    Stabilize Module
    Smooth camera jitter and lock down shots.
    The stabilize module can lock down camera motion or stabilize moving objects for visual effects and finishing work. A smooth option with selectable anchor frames helps reduce high frequency jitters while maintaining original camera motion. Center, scale or crop stabilized footage based on user driven planar tracking.
    Insert Module
    Render match moves and screen inserts with motion blur or mesh warp distortion.
    The Insert Module allows you to render an image onto a tracked surface within mocha Pro. Powerful mesh warp distortion tool allows the user to wrap and bend inserts onto non flat surfaces. Combines with Lens Module for realistic VFX compositing on distorted footage.
    Version: 4.1.2
