Productivity Matlab 2015a 8.5.0.197613
Productivity
    Matlab 2015a
    7.35 GB
    Version: 8.5.0.197613
    OS version: Mac OS X 10.9.5 or later
    RAM minimum: 2 GB
    Video RAM: No specific
    Version 8.5.0 (R2015a):
    New Features, Bug Fixes, Compatibility Considerations
    Desktop
    Documentation: Integrate documentation for custom toolboxes into the MATLAB Help Browser
    Documentation: Determine when feature introduced
    Array Size Limit: Limit maximum array size to prevent unintended creation of very large matrices
    Tab Completion: Complete class properties and methods while editing class definition files
    User Interface Preferences: Control user interface language
    Language and Programming
    repelem Function: Repeat copies of array elements to create a larger array
    sort Function: Now preserves shape of cell array of string inputs
    isenum Function: Determine if variable is enumeration
    milliseconds Function: Convert duration to number of milliseconds
    Publishing Markup: Include external file content
    fullfile Function: Maintain all double-dot symbols
    Python Objects: Indexing Support
    Python Version 3.4: MATLAB Support
    MATLAB Engine for Python: Support for startup options
    MATLAB Engine for Python: Support for Unicode in Python 2.7
    Conversion of Character Arrays to Java Strings: Preserve null characters
    WSDL Web Services Documents: Limitations
    Unit Testing Framework: Tag tests for categorization and selection
    Unit Testing Framework: Run tests in parallel
    Unit Testing Framework: Share variables between tests in scripts
    Unit Testing Framework: Use prebuilt test fixtures
    Unit Testing Framework: Compare objects using isequaln
    Unit Testing Framework: Use homogeneous expected causes with Throws constraint
    Git Source Control Integration: View branch details and delete branches
    C Matrix Library: New functions
    Functionality being removed or changed
    Mathematics
    discretize Function: Group numeric data into bins or categories
    Descriptive Statistics: Omit NaN values in basic statistical calculations, including max, min, mean, median, sum, var, std, and cov
    ismembertol and uniquetol Functions: Perform set comparisons using a tolerance
    Random Numbers: Generate random numbers using the double-precision, SIMD-oriented Fast Mersenne Twister (dSFMT) algorithm
    nearestNeighbor Function: Determine nearest alphaShape boundary point
    Data Import and Export
    Datastore: Read one complete file with 'file' option for ReadSize property
    Datastore: Read data in parallel from a datastore with partition function using Parallel Computing Toolbox
    webwrite Function: Send data to RESTful Web services using HTTP POST method
    webread and websave Functions: Request data from RESTful Web services using HTTP POST method
    xlsread and readtable Functions: Read larger spreadsheet files from Excel software
    textscan and readtable Functions: Return consistent results when reading quoted strings
    Scientific File Format Libraries: Upgrades
    Graphics
    drawnow Function: Improve performance in animation loops with new option
    Performance
    MapReduce: Run mapreduce algorithms on any computer cluster that supports parallel pools using MATLAB Distributed Computing Server
    Interpolation Functions: Execute faster with multithreaded calculations
    Hardware Support
    IP camera: Acquire video directly from Internet Protocol cameras
    BeagleBone Black Hardware: Access BeagleBone Black hardware with the MATLAB Support Package for BeagleBone Black Hardware
    Arduino Hardware: Access to Arduino Leonardo and other boards with the MATLAB Support Package for Arduino Hardware
    Arduino Hardware: New configurePin function
    ↑ Info
    Explore new ideas
    MATLAB® is the high-level language and interactive environment used by millions of engineers and scientists worldwide. It lets you explore and visualize ideas and collaborate across disciplines including signal and image processing, communications, control systems, and computational finance.
    Put your ideas into action
    You can use MATLAB in projects such as modeling energy consumption to build smart power grids, developing control algorithms for hypersonic vehicles, analyzing weather data to visualize the track and intensity of hurricanes, and running millions of simulations to pinpoint optimal dosing for antibiotics.
    System requirements
    Intel Mac OS X 10.9.5 or later
    Ứng dụng MAC OS X Update
