Utilities MAMP PRO 3.2.1
OS version: Mac OS X 10.6.6+
    Version: 3.2.1
    245.8 MB
    Block connections to mamp.info (77.91.233.174)
    Version Release Date: 2015-04-10
    SHA-1: 46df4d77528a7552a911925cb2373da751da46d7
    What's New?
    MAMP & MAMP PRO 3.2.1
    Updated components: curl 7.41.0, PHPUnit 4.6.2, phpMyAdmin 4.4.1.1
    MAMP
    Fixed a httpd.conf problem that prevented Apache from starting
    MAMP PRO
    Dynamic DNS updates correctly when Apache starts
    Every host gets the IPv6 entry ::1 in /etc/hosts
    Updated components: MAMP PRO Uninstaller
    Components: Show
    Direct Download Link: http://downloads6.mamp.info/MAMP-PRO/releases/3.2/MAMP_MAMP_PRO_3.2.1.pkg
    More Info: http://www.mamp.info/en/mamp-pro/
    MAMP PRO - Your local web development solution
    mamp.info
    Documentation: http://www.mamp.info/en/documentation/
    MAMP & MAMP PRO - your local web development solution for PHP and WordPress development
    MAMP GmbH is the manufacturer of the award-winning MAMP software.
    mamp.info
    https://whatimg.com/i/O4LPMN_thumb.png
    Develop and test websites locally
    MAMP PRO is the commercial, professional grade version of the classic local server environment: MAMP. Designed for professional web developers and programmers, MAMP PRO allows easy installation and administration of their development environment.
    https://whatimg.com/i/36nAwj.png
    Multi-PHP
    Run different versions of PHP at once
    MAMP Pro has always offered multiple versions of PHP. This was convenient if you had different projects using different versions of PHP, but required a restart of MAMP PRO when you wanted to change projects. If, for instance, you needed to work on a host which used a different version of PHP, you had to restart the servers and change the PHP version to work on that particular virtual host. With the new MAMP PRO you can configure your PHP versions on a per host basis using CGI Mode. Now you can conveniently switch between virtual hosts using different PHP versions on the fly.
    https://whatimg.com/i/hoB7Ac.png
    Virtual Server
    Set up any number of virtual servers
    You can set up and test any number of virtual servers without the danger of affecting your live system. The local name resolution is performed by MAMP PRO. For each project, you can create a virtual host and conveniently test your programs in detail. Whether you create a page using a CMS, integrate a shopping-cart, or create a WordPress template - MAMP PRO is there to provide the perfect test environment. With unlimited server-hosts you can separate all your projects and make them accessible to your local network or even the internet. To simulate a very authentic environment, MAMP PRO can activate the local mail server, as well as the sending of emails via PHP.
    https://whatimg.com/i/Xv1LgL.png
    Extras
    Install WordPress, Joomla, Drupal, etc with just one click
    An Extra is a collection of files or library, which has been tested and configured by the MAMP PRO team. When setting up a new virtual host you can also choose and Extra which will automatically be installed. You can also install Extras on existing hosts. The selection of extras is always being updated and expanded.
    https://whatimg.com/i/7kX5a5.png
    Dynamic DNS
    Allow External Access
    With MAMP PRO, you can easily connect your local server to the internet with an existing Dynamic DNS provider. You can conveniently provide access to your work to clients and prospects over the internet. With the option to set up many virtual hosts, you can easily offer alternative configurations or suggestions. With MAMP PRO 3.0 the DNS-O-Matic service is integrated. Now you have a huge selection of Dyn-DNS service providers, many of which are free of charge.
    https://whatimg.com/i/QgL90T.png
    Postfix
    Test PHP scripts with a Mail-Server
    Every Mac OS X computer comes pre-installed with a default Mail-Server. This Mail-Server can be activated through the MAMP PRO interface and it’s functionality used via PHP scripts. With this Mail-Server you can setup up an account through a host provider. This provides a reliable email connection and avoids problems with spam filters.
    https://whatimg.com/i/SA9SMD.png
    Apache
    Switch Apache Modules on and off
    With MAMP PRO you can quickly setup a test environment without the need to install and configure Apache. Work on multiple projects simultaneously in parallel. A staging-server is easily setup up with just a few mouse clicks. Apache modules can be activated and deactivated through the MAMP interface. This allows you to quickly build a custom local server environment to mirror the one on your live server.
    https://whatimg.com/i/hQEX8y.png
    MAMP Features
    Functionality of MAMP
    MAMP PRO is the commercial, professional grade version of the classic local server environment for OS X. That is, the freely available standard version is automatically installed with MAMP PRO. With MAMP PRO comes all the functionality of MAMP including MySQL, Apache, PHP, Perl, and Python.
  1. Anonymous
    Version: 3.2.1
