Productivity IMT Exif Remover 1.40
Cách đơn giản nhất để loại bỏ thông tin EXIF từ các bức ảnh kỹ thuật số trên Mac OS X.
    IMT Exif Remover
    1.26 MB
    Name: IMT Exif Remover
    Version: 1.40
    OS version: OS X 10.5 or later
    Block connections to: www.imactools.com
    Release Date: March 13, 2014
    Adjust user interface
    Implement adding images by dragging and dropping from Finder
    Fixes various bugs
    The easiest way to remove EXIF information away from digital photo images on Mac OS X.
    Delete EXIF Data in 3 Steps
    Run IMT Exif Remover
    Find the IMT Exif Remover in "Applications" after successfully installed.
    Add JPEG Images
    Choose jpeg image files from Finder, and drag over IMT Exif Remover window, then drop to add the image files to the processing list.
    Save and Done
    Click "Save" and choose a location for the output result image files. Then you will get all jpeg files without EXIF information data.
    EXIF-Data shows many information about the photo, including date time that the photo was taken, camera model, and other important parameters used for taking the photo.
    Exchangeable image file format (Exif) is a standard that specifies the formats for images and ancillary tags used by digital cameras (including smartphones), scanners and other systems handling image files recorded by digital cameras. The specification uses the following existing file formats with the addition of specific metadata tags: JPEG DCT for compressed image files, TIFF Rev. 6.0 (RGB or YCbCr) for uncompressed image files.
    Exif data is embedded within the image file itself. Sometimes, you may want to remove the Exif data to protect your personal privacy, IMT Exif Remover is a great choice to erase exif data in batch.
