Final Cut Pro 10.2.1
Phần mềm sử lý video của Apple
    Version: 10.1.4
    OS version: 10.9.2 or later
    RAM minimum: 4GB
    Video RAM: 256MB
    Optimized for the new Mac Pro, Final Cut Pro lets you edit and deliver like never before. Work with multiple streams of 4K ProRes at full resolution. Play back complex graphics and effects in real time without rendering. Even output your 4K video to ultra-high-definition displays via HDMI and Thunderbolt 2.
    Native MXF import, edit, and export with Pro Video Formats 2.0 software update
    Option to export AVC-Intra MXF files
    Support for import and editing with Panasonic AVC-LongG media
    Fixes issues with automatic library backups
    Fixes a problem where clips with certain frame rates from Canon and Sanyo cameras would not import properly
    Resolves issues that could interrupt long imports when App Nap is enabled
    Stabilization and Rolling Shutter reduction works correctly with 240fps video
    More information:
    https://www.apple.com/final-cut-pro/
    Final Cut Pro X
    Final Cut Pro X revolutionizes post-production with 360° video editing and motion graphics, 4K HDR support, and advanced tools for color correction.
    apple.com
    https://itunes.apple.com/app/final-cut-pro/id424389933?mt=12
    ‎Final Cut Pro
    ‎Redesigned from the ground up, Final Cut Pro combines revolutionary video editing with powerful media organization and incredible performance to let you create at the speed of thought. Revolutionary Video Editing • The Magnetic Timeline uses...
    itunes.apple.com
    Completely redesigned from the ground up, Final Cut Pro adds extraordinary speed, quality, and flexibility to every part of the post-production workflow.
    • Assemble clips in the Magnetic Timeline without clip collisions or sync problems
    • Use Clip Connections to attach B-roll, sound effects, and music to the timeline
    • Reduce clutter by grouping clips into a Compound Clip.
    • Perfect your pacing right in the timeline with the Inline Precision Editor
    • Cycle through different shots, graphics, or effects at one place in the timeline with Auditions
    • Edit multi-camera projects with automatic sync and support for up to 64 camera angles
    Powerful Media Organization
    • Organize your work within libraries for efficient media management and collaboration
    • Work natively with a broad range of formats including RED, AVCHD, H.264 from DSLRs, and more
    • Content Auto-Analysis captures camera metadata and analyzes shots in the background
    • Create and apply custom keywords on the fly as you select ranges in clips
    • Smart Collections let you dynamically organize content and find any shot in a few clicks
    Incredible Performance
    • Final Cut Pro uses all the GPUs in your Mac for superior real-time playback performance and fast background rendering
    • 64-bit architecture uses all the RAM in your system for larger projects and richer effects
    • Background processing lets you keep working without interruption
    • External monitoring lets you route video and audio through HDMI or third-party Thunderbolt and PCIe devices
    Compelling, Customizable Effects
    • Preview effects to see how they look with your footage before applying them
    • Change the look of titles, transitions, and effects using intuitive controls
    • Control effects with precision using a keyframe editor that appears directly in the timeline
    • Use third-party FxPlug plug-ins with custom interfaces and dual-GPU support
    Integrated Audio Editing
    • Expand and edit multichannel audio files directly in the timeline
    • Let Final Cut Pro repair significant audio problems such as hum, excessive noise, and more
    • Sync DSLR video with separate audio in a single step, with instant audio waveform matching
    Intuitive Color Grading
    • Improve the look of any clip with the single-click Balance Color feature
    • Apply the Match Color feature to match the looks of two clips shot under different conditions
    • Manipulate color, saturation, and exposure with the Color Board
    • Fine tune color for a specific color range or area of the screen using keying and masks
    One-Step, Optimized Output
    • Deliver projects for playback on Apple devices and websites such as Vimeo, YouTube, and Facebook
    • Use themed menus to quickly author and burn a DVD or Blu-ray disc
    • Export customized audio stems and multiple versions of a finished video using Roles metadata
    • Import and export XML to support third-party workflows
  1. Final Cut Pro X
  2. Final Cut Pro [MAS]
    Version: 10.2.1
    Phiện bản 10.2.1
  2. fan
    Version: 10.2
  3. post
    Version: 10.1.4
  4. admin
    Version: 10.1.4
