1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Contact me if you have problems logging in with Facebook or google +
Music Bongiovi Digital Power Station (DPS) 1.0.5
    Name: Bongiovi Digital Power Station (DPS)
    Version: 1.0.5
    Processor type(s) & speed: 64bit Intel 1GHz
    RAM minimum: 2GB
    Compatibility Notes: although 10.7 and higher are supported, Bongiovi claims that only 10.10 is FULLY compatible
    Instructions:
    Install application
    Run patch
    Application may not successfully register without access to internet so allow it access
    This version includes the fix for 100% CPU usage. This may be the cause for some users getting lag in the volume control and a few other symptoms. This version also allows for 24 or 32bit driver modes in Audio/MIDI settings for those of you connecting to home theatre gear.
    Release Notes:
    http://dpsinsider.com/forums/forum/dps-plug-in-for-computers/dps-system-wide-plug-in-for-mac-beta
    Bongiovi DPS is a patented algorithm that optimizes audio in real time.
    DPS Profiles are created and implemented for ultimate audio flexibility in any sound scenario.
    At the heart of DPS is our profile system. A DPS profile contains over 120 calibration points that configures the patented DPS algorithm. Each profile is carefully crafted by Bongiovi acoustic engineers. These profiles are used to optimize the audio signal in real-time; for the output device (speakers), environment (high noise), and to emphasize a “sound” or other desired effects .
    Below are a few examples of how Bongiovi DPS can work for you:: Show
    Version: 1.0.5
