Music Bitwig Studio 1.1.8
Music
    Bitwig Studio
    194.2 MB
    Version: 1.1.8
    RAM minimum: 2 GB
    Video RAM:
    Courtesy of OLSNAD
    See Instructions.txt for instructions
    Release Date: May 21, 2015
    Changes in Bitwig Studio 1.1.8
    NEW German user guide.
    FIXED "Duplicate/Remove Time" command doesn't move cue markers.
    FIXED Crash when scaling launcher clip via inspector.
    FIXED Icons for Bitwig Studio in the debian package should not have spaces in their names.
    FIXED Modifiers for making selections (multi-select, range select) don't work while the caps lock is on.
    FIXED Regression: Clicks in Stretch HD mode.
    FIXED Crash if dragging a preset to device in a nested chain to replace and before the preset has been loaded deleting the nested chain that contains the device that will be replaced.
    FIXED Regression in 1.1.7: crash when scaling raw audio after bouncing via clip inspector.
    FIXED "Copy modulation to all layers" works only for layers with exactly the same devices in chain.
    FIXED Moving cue markers via inspector may crash.
    FIXED Popup text field for renaming cue markers sometimes appears too far on the right.
    FIXED Crash when using onset-shift inspector buttons in some cases.
    FIXED Audio engine crashes sometimes when deleting a sandboxed plugin.
    FIXED Long audio files are very slow to paint in RAW mode.
    Set to neutral leech for 24 hours due to previous release of 1.1.8 missing files.
    Bitwig Studio is a dynamic software solution for music creation and performance to realize all of your musical ideas in every stage of production.From sound design to music creation, discover the new standard in customized workflow. Bitwig Studio inspires you to take greater control of your productions, giving you access to every aspect of your workflow as needed. Streamline your creative process and quickly take your music from ideas to complete songs, tracks and compositions. With Bitwig Studio, you’re in command of a workflow that works best for you.
    Version: 1.1.8
    Ứng dụng MAC OS X Update
