Music Audirvana Plus 2.1.1
OS version: OS X 10.6 or later
    Version: 2.0.10
    Block connections to: audirvana.com
    Courtesy of HIOb
    Version 2.0.10:
    • Display all tracks/albums in children playlists when selecting a playlist folder.
    • Add file type and album artist as smart playlist criteria.
    • Add file location as last sort criteria for the track list default sort criteria to still sort for files with missing metadata.
    Bug fixes:
    • Fix to skip corrupted FLAC files instead of hanging.
    • Fix clicking on license file not loading it when the trial license has expired.
    • Fix noise reading some rare 16bit FLAC files.
    Audirvana Plus
    Following the acclaimed Audirvana Plus versions, specially the one including Direct Mode and Integer Mode, Audirvana Plus is now offering a full featured library manager that can scale up to more than 100,000 tracks.
    Catalog all your music library and easily retrieve your albums and tracks with optimized user interface. Edit metadata with advanced tags for jazz and classical music
    With the utmost sound quality with 64-bit internal processing, Direct Mode, Integer Mode, iZotope algorithms, native DSD streaming, SysOptimizer and Audio Unit plugins support
    FEATURES:
    Native playing of FLAC, libSndFile (WAV, AIFF, ...), ALAC and other quicktime formats (AAC, MP3, ...)
    Direct sound path, directly to the !CoreAudio HAL for pure bit perfect sound
    Audio Device exclusive access mode
    HAL I/O using DAC native physical formats "Integer Mode" (instead of CoreAudio 32bit float)
    Automatic sample rate switching
    Up/Oversampling capability
    Plays completely from memory
    Tracks are loaded, decoded and sample rate converted in a memory buffer before being played
    Minimizing CPU and hard drive activity to lessen sources of interference
    Gapless playback by using a double buffering mechanism (playing track and next track)
    Transparent split load for loading tracks of any size
    Background tracks loading/decoding (including sample rate conversion)
    Playlist (m3u & m3u8 formats) load/save
    Handles Apple IR Remote
  1. Audirvana Plus
    Version: 2.0.10
