Productivity AKVIS SmartMask 7.0.1924
Photography
    AKVIS SmartMask
    Name: AKVIS SmartMask
    Version: 7.0.1924 (11865)
    Mac Platform: UB
    OS version: n/a
    Processor type(s) & speed: n/a
    RAM minimum: 2 Gb
    Drag the AKVIS SmartMask.app in the Applications folder. Drag AKVIS SmartMask Plugin.app into PhotoShop plug-in folder.
    When you first open it select Try It and choose Deluxe or Business.
    Gives you 999999 days of trial days!
    Notes:
    Block outgoing connections (Little Snitch, Hands Off!.. or something like that) Disable automatic update checks
    http://akvis.com/en/smartmask/index.php
    Make Selections with AKVIS SmartMask: Image Masking Made Easy!
    AKVIS SmartMask is an efficient selection tool that saves you time and is fun to use. It lets masking objects on images and removing/replacing backgrounds in minutes. Save time on complex selections!
    akvis.com
    AKVIS SmartMask is an efficient selection tool that saves time and is fun to use. There are many occasions when you need to target a specific area of an image. It is often necessary to highlight regions to which an effect or correction should be applied. Creation of photo collages and montages requires a precise selection of objects. This can be a painful task because many objects don't have clearly defined edges and fade into the background. For instance, just try selecting yourself in a group photo. AKVIS SmartMask makes even a difficult selection incredibly simple! Now, you can spend less of your time on selection of objects and more of it on creativity.
    Version: 7.0.1924
