010 Editor 6.0.2
    010 Editor
    14.45 MB
    OS version:
    OS X 10.5 or later
    File Format:
    • DMG
    Version: 6.0.2
    OS version: OS X 10.5 or later
    Block Connections to: sweetscape.com
    Note: Make sure to disable checking for updates inside app preferences (Preferences > General > Check For Updates) to prevent reg details from being blacklisted. Alternatively, you could block app with Little Snitch. This isn't necessary if you disable check in preferences since the only time the app tries to validate details is during update check. If you do get blacklisted (ie. you let it check for updates), you can reset registration/blacklist by deleting this file in current user folder. You will need invisible files enabled to see it. ~\.config\SweetScape\010 Editor.ini
    What's New?
    Version 6.0.2 - April 13, 2015
    Fixed problem opening physical drives on Linux.
    Fixed error using 'Copy As > Copy as Base64' and 'Copy As > Copy as Uuencoding'.
    Now display an error when an invalid character constant is encountered in a script or template.
    Fixed FILETIME error in the Inspector on Linux/Mac 64-bit.
    Fixed error in the first result using Find Strings on a custom range.
    Updated color for the Welcome and New Version dialogs.
    Fixed error in the documentation for the Exec function about the function's return value.
    Fixed error message in the footer of the Manual on the Mac.
    Full Release Notes:
    010 Editor - The Professional Text/Hex Editor with Binary Templates
    Text Editor
    Edit text files, Unicode and UTF-8 files, C/C++ source code, etc. Unlimited undo and powerful editing and scripting tools.
    Hex Editor
    Unequalled binary editing performance. Edit any file of any size. Use powerful Binary Templates technology to understand binary data.
    Disk Editor
    Find and fix programs with hard drives, memory keys, flash drives, CD-ROMs, etc.
    Process Editor
    Investigate and modify memory from processes.
    . . . plus much more.
    Powerful Workspace view including file explorer.
    Convert data between ASCII, EBCDIC, Unicode, UTF-8, etc.
    Inspector allows data to be quickly interpreted in different formats.
    Mark important bytes using Bookmarks.
    Full integrated expression calculator.
    Apply Highlighting rules to identify bytes in a file.
    Import or export data in Intel Hex Format, Motorola S-Records, Hex Text, C/C++/Java Code, Base64, Uuencoding, RTF, or HTML.
    Printing with full print preview, headers, footers, and margins.
    Version: 6.0.2
