Acer Veriton M6620G
BIOS P21-A0
BIOS P21-A0
P21-A0.bin.zip
motherboard code and file bios old error ?.i need bios Acer Veriton M6620G
here can give motherboard code ???????????????????
100% OK, just now finished programming bricked ASUS and all works fine. As I mentioned before, 2 mobos, 2 chips - same BIOS, same issue. After flashing "dirty" BIOS mobos behave differently to what happens on your file.programming is not complete. It is not related to the BIOS file, you need to check the tool and the BIOS chip
Clean ME please.
check more hardware.Doesn't work, behaves like uncleaned image. 3-3 beeps, no display.
tested on 3 mobos, I took one working properly and after flash the same 3-3 beepscheck more hardware.
